GoPro Hero 3+ Silver Edition Motherboard Replacement
Introdução
Ir para o passo 1Are the circuits of your GoPro's motherboard fried from water damage? This guide provides steps on how to replace a GoPro Hero 3+ Silver Motherboard and get your camera back in working condition.
Push the tab on the back of the device left to remove the plate covering the battery.
Insert a plastic opening tool in between the front face plate and the black housing.
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
3 outras pessoas executaram este guia.
