GoPro Hero+ LCD Lens Replacement
Introdução
Ir para o passo 1To remove the lens assembly, you must remove some internal parts first. Some of these screws are in tight places, so they will be tedious to access.
O que você precisa
Peças
Ferramentas
Exibir mais…
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Pry around the panel to ensure it is not attached to the device.
Move the panel to the side so you can access the internal components.
а где можно купить вот этот шлейф соединяющий дисплей и плату.???
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
Use a pair of tweezers to disconnect the battery connector from the motherboard.
Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
Lift the battery connector straight up.
hi what kind battery can replace for hero+?
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
Gear Up For Future Repairs
Shop all2Comentários do guia
I'm curious if you have any suggestions for sourcing the replacement part.
No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
WPN - Responder
