Ir para o conteúdo principal
GoPro Hero+ LCD Lens Replacement
Matthew Tinkey
Matthew Tinkey e 4 outros colaboradores
Última atualização em May 28, 2021
5 - 10 minutos
Difícil
Introdução
Ir para o passo 1
To remove the lens assembly, you must remove some internal parts first. Some of these screws are in tight places, so they will be tedious to access.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, imagem 1 %32 GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, imagem 2 %32
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
    WPN - Responder
  2. GoPro Hero+ LCD Lens Replacement: passo 2, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Lens Replacement: passo 3, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 3, imagem 2 %32
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    а где можно купить вот этот шлейф соединяющий дисплей и плату.???
    Александр «ivkadre» Карпенко - Responder
  4. GoPro Hero+ LCD Lens Replacement, Battery: passo 4, imagem 1 %32
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Lens Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Lens Replacement: passo 6, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 6, imagem 2 %32
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Lens Replacement: passo 7, imagem 1 %32
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Lift the battery connector straight up.
    glenn tanner - Responder
    hi what kind battery can replace for hero+?
    sherwin_0011 - Responder
  8. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 1 %32 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 2 %32 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, imagem 3 %32
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Lens Replacement: passo 9, imagem 1 %32
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Lens Replacement: passo 10, imagem 1 %32
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Lens Replacement: passo 11, imagem 1 %32
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Lens Replacement, Image Sensor: passo 12, imagem 1 %32
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
  13. GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, imagem 1 %32 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, imagem 2 %32 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, imagem 3 %32
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
  14. GoPro Hero+ LCD Lens Replacement: passo 14, imagem 1 %32
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
  15. GoPro Hero+ LCD Lens Replacement: passo 15, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 15, imagem 2 %32 GoPro Hero+ LCD Lens Replacement: passo 15, imagem 3 %32
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
  16. GoPro Hero+ LCD Lens Replacement, Lens: passo 16, imagem 1 %32 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, imagem 2 %32 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, imagem 3 %32
    • Remove the two 4 mm Phillips #000 screws securing the top button.
  17. GoPro Hero+ LCD Lens Replacement: passo 17, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 17, imagem 2 %32
    • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
  18. GoPro Hero+ LCD Lens Replacement: passo 18, imagem 1 %32 GoPro Hero+ LCD Lens Replacement: passo 18, imagem 2 %32 GoPro Hero+ LCD Lens Replacement: passo 18, imagem 3 %32
    • Gently lift the lens up and out of the device.
Conclusão
Matthew Tinkey
Membro desde: 08/27/15
922 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro de USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membros
Autoria de 20 guias
2Comentários do guia
I'm curious if you have any suggestions for sourcing the replacement part.
Bridgetown Electronics Repair - Responder
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 6,665
