Ir para o conteúdo principal
GermGuardian AC4825E UV-C Bulb Replacement
Tim Lourenco
Tim Lourenco e um outro colaborador
Última atualização em May 12, 2022
3 - 4 minutos
Fácil
The UV-C bulb is a vital tool for the GermGuardian AC4825E. The light eliminates bacteria, spores, and other microorganisms in the air to assist with air purification. When this bulb goes out, the UV bulb change indicator near the control panel on top of the purifier will flash blue. When this happens, it's time to replace the UV-C bulb. This guide will demonstrate the removal process for the UV-C bulb.
O que você precisa
Ferramentas
A iFixit ganha comissão quando você compra por estes links.
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: passo 1, imagem 1 %32
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: passo 2, imagem 1 %32 GermGuardian AC4825E UV-C Bulb Replacement: passo 2, imagem 2 %32
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: passo 3, imagem 1 %32 GermGuardian AC4825E UV-C Bulb Replacement: passo 3, imagem 2 %32 GermGuardian AC4825E UV-C Bulb Replacement: passo 3, imagem 3 %32
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: passo 4, imagem 1 %32
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: passo 5, imagem 1 %32 GermGuardian AC4825E UV-C Bulb Replacement: passo 5, imagem 2 %32 GermGuardian AC4825E UV-C Bulb Replacement: passo 5, imagem 3 %32
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Conclusão
Tim Lourenco
Membro desde: 03/28/22
329 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-1, Mellen Spring 2022 Membro de UMass Dartmouth, Team 2-1, Mellen Spring 2022
UMASSD-MELLEN-S22S2G1
Membros da 4
Autoria de 2 guias
Um comentário
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 44
Duração total: 2,413
