Ir para o conteúdo principal
Garmin inReach Mini Battery Replacement
Ellie Taube
Ellie Taube e 5 outros colaboradores
Última atualização em May 7, 2024
20 - 35 minutos
Moderado
Introdução
Ir para o passo 1
This guide demonstrates how to replace the battery of a Garmin inReach Mini. This devices utilizes a rechargeable, lithium ion battery. The battery is located on the inside of the back hard case. When removing the battery, make sure all necessary cables and power sources are disconnected from the battery in order to prevent an electrical hazard. After replacing the battery, it is crucial to dispose of the old battery at a specialized e-waste collection site or battery-recycling location.
O que você precisa
Ferramentas
Exibir mais…
  1. Garmin inReach Mini Battery Replacement, Nylon Strap: passo 1, imagem 1 %32
    • Place the device on a level surface with the back hard case facing up.
  2. Garmin inReach Mini Battery Replacement: passo 2, imagem 1 %32 Garmin inReach Mini Battery Replacement: passo 2, imagem 2 %32 Garmin inReach Mini Battery Replacement: passo 2, imagem 3 %32
    • Use the T5 to remove the 1.9mm screw attached to the nylon strap.
    • Remove the nylon strap.
  3. Garmin inReach Mini Battery Replacement, Back Case: passo 3, imagem 1 %32 Garmin inReach Mini Battery Replacement, Back Case: passo 3, imagem 2 %32 Garmin inReach Mini Battery Replacement, Back Case: passo 3, imagem 3 %32
    • Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
    Which head does this screw have ?
    Sebastien Chauvin - Responder
  4. Garmin inReach Mini Battery Replacement: passo 4, imagem 1 %32 Garmin inReach Mini Battery Replacement: passo 4, imagem 2 %32 Garmin inReach Mini Battery Replacement: passo 4, imagem 3 %32
    • Lastly, lift the protective cap on the side of the device that states "SOS". Slowly pull it to the right in order to remove the back hard case.
  5. Garmin inReach Mini Battery Replacement: passo 5, imagem 1 %32 Garmin inReach Mini Battery Replacement: passo 5, imagem 2 %32 Garmin inReach Mini Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the precision tweezers with the round tips, detach the battery connector from the motherboard.
    • Disconnecting the battery stops the flow of power into the motherboard. This is for your own safety.
    • If utilizing this guide as a prerequisite to replacing the motherboard, it is crucial not to damage the cable connecting the battery to the motherboard. When the new motherboard is introduced, it will need to be reconnected with that cable.
  6. Garmin inReach Mini Battery Replacement, Battery: passo 6, imagem 1 %32 Garmin inReach Mini Battery Replacement, Battery: passo 6, imagem 2 %32 Garmin inReach Mini Battery Replacement, Battery: passo 6, imagem 3 %32
    • After removing the back hard case, users can access the battery on the inside of the back hard case.
    • Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
  7. Garmin inReach Mini Battery Replacement: passo 7, imagem 1 %32 Garmin inReach Mini Battery Replacement: passo 7, imagem 2 %32
    • Create leverage by inserting the opening tool underneath the battery. Lift the battery up until it detaches from the case, then remove the battery entirely.
  8. Garmin inReach Mini Battery Replacement: passo 8, imagem 1 %32
    • Then using the precision tweezers with the round tips, lightly pull the battery out from the case.
    • The battery is attached to the back hard case with an adhesive.
    • Dispose of the lithium ion battery in a safe manner in order to prevent electrical hazards. Keep the battery dry and cool.
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
Any idea where to buy a replacement motherboard? The battery in mine corroded and the battery connector broke off.
Ashley Hill - Responder
where to buy the battery from? is it the same battery for Garmin inReach Mini 2?
Akkad - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 95
Ao todo: 5,269
