Ir para o conteúdo principal
Garmin Fenix 3 Display Assembly Replacement
Adam Estabrook
Adam Estabrook e 2 outros colaboradores
Última atualização em 22 de ago de 2024
5 minutos
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
If your watch face is damaged, cracked, or chipped, you can learn how to replace it using this guide. This guide involves simply unscrewing screws from the watch face and carefully disconnecting the screen’s ribbon cable from the motherboard. You will need a T6 Torx screwdriver and a spudger.
O que você precisa
Ferramentas
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: passo 2, imagem 1 %32
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: passo 4, imagem 1 %32
    • Set the watch face aside.
    Hi can i replace only lcd because my sapphire glass is ok
    Drazen Popadic - Responder
Conclusão
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
3Comentários do guia
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Responder
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 73
Ao todo: 10,098
