Garmin Fenix 2 Battery Replacement
Introdução
Ir para o passo 1We will be replacing the battery in the Garmin Fenix 2 watch. You should have a Torx T9 screwdriver on hand and a nylon spudger.
O que você precisa
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
Good information, but :
- spudger not really needed, nail is enough.
- missing the one regarding the need for a soldering iron ! The old battery needs to be unsoldered and the new one soldered to the inside wiring. Not so difficult but soldering iron needed !
Got a spare battery on eBay (vendor is http://akku-wechsel.de). Delivery was very fast. After replacement I went from 6~8 hours life to 3~4 weeks :) So happy with the upgrade !
11 outras pessoas executaram este guia.
7Comentários do guia
can you tell us exactly which battery should be used? Thanks in advance!
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
How do I disconnect and reconnect wires from power ribbon?
You need a soldering iron... I could do it without any experience doing so. Replacement battery I got online seems to give me a longer life that the original one. So happy I did the exchange ! :)
