Ir para o conteúdo principal
Gamma Scout Geiger Counter Battery Replacement
Bela Sajgo
Bela Sajgo e 2 outros colaboradores
Última atualização em May 12, 2024
20 - 45 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
The Gamma Scout geiger counters are one of the most known geiger counters in Europe. These geiger counters are made in Germany. They have a built in long lasting (up to 10 years) lithium battery. Because of the extremely low power consumption of the device (10 microamps), the battery has to be soldered directly onto the PCB. This guide shows you step by step how to replace the internal lithium battery of your Gamma Scout geiger counter (applicable only for the non-rechargeable models).
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Gamma Scout Geiger Counter Battery Replacement, Preparation: passo 1, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Preparation: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • Prepare your Gamma Scout geiger counter for the battery replacement.
    • If your geiger counter is in a holster, remove the holster from the geiger counter.
    • Prepare the necessary tools: a Phillips #1 screwdriver, a thin flathead screwdriver or a plastic spudger, a desoldering pump, a soldering station or a soldering iron, a wire cutter.
  2. Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: passo 2, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: passo 2, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: passo 2, imagem 3 %32
    • Locate the cover of the USB port on the bottom side of the geiger counter.
    • Remove the USB port cover using a thin flathead screwdriver or using a spudger.
  3. Gamma Scout Geiger Counter Battery Replacement, Locating the screws: passo 3, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Locating the screws: passo 3, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Locating the screws: passo 3, imagem 3 %32
    • Locate the three screws on the back side of your device.
    • Notice that two of your screws are covered by the serial number sticker.
    • You either have to partially lift up this sticker to get access to the screws, or you can choose to cut two round holes into the sticker.
  4. Gamma Scout Geiger Counter Battery Replacement, Removing the screws: passo 4, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the screws: passo 4, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the screws: passo 4, imagem 3 %32
    • Remove the three screws using a Phillips #1 screwdriver.
  5. Gamma Scout Geiger Counter Battery Replacement, Opening the case: passo 5, imagem 1 %32
    • After you have removed all the three screws, the case should easily come apart.
    • For this step you will not need any tools, because the front and back parts of the case will get apart easily.
    • Notice that the PCB will remain attached to the front side of the case, so it is recommended to lift up the back side of the case while holding the device upside-down.
    • Make sure not to touch the upper part of the PCB or the geiger tube, because these parts of the device are under high voltage.
    • Be careful not to hit or touch the front end window of the geiger tube, because it is made out of a very thin and very fragile material.
  6. Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: passo 6, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: passo 6, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: passo 6, imagem 3 %32
    • To be able to remove the PCB from the case, you will need to disconnect the flat-flex cable that goes to the keys located at the front side of the device.
    • For this step you will need a spudger or a pair of nonconducting pliers, to push off or to pull down the connector from the pin header.
    • This step requires some force to remove the connector from the pin header, but be careful not to tear apart or rip off the connector from the flat-flex cable.
    • If you decide to use a pair of pliers for this step, make sure it is made out of plastic or some other non-conducting material, because it will touch the PCB and it could create a short-circuit.
  7. Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: passo 7, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: passo 7, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: passo 7, imagem 3 %32
    • After you successfully removed the PCB from the case, the next step is to cut the cable tie that is holding the old lithium battery onto the PCB using a wire cutter.
    • Next you will have to remove the lithium battery from the PCB, by cutting its two terminals that are soldered onto the PCB, with a wire cutter.
    • As an alternative, you also can directly desolder the lithium battery, without cutting its terminals.
    • Make sure not to touch the upper part of the PCB or the geiger tube, because these parts of the device are under high voltage, until the battery is removed.
  8. Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: passo 8, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: passo 8, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: passo 8, imagem 3 %32
    • Now that the battery is removed, you have to desolder the remaining parts of the battery terminals.
    • After that, you have to clean the solder joints where the two terminals of the battery were soldered onto.
    • For cleaning the solder joints and to remove the remaining solder, you can use a desoldering pump or a solder wick.
    • If you have excess flux residue on the PCB, you can clean it with isopropyl alcohol.
  9. Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: passo 9, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: passo 9, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: passo 9, imagem 3 %32
    • Now that your solder joints are clean, prepare the new battery by bending its terminals into the desired form.
    • You can also cut down the excess part of the battery terminals to make the insertion easier, but do not cut them too short.
    • After you inserted the battery terminals through the holes of the PCB (observe correct polarity), secure the new battery onto the PCB with a new cable tie.
  10. Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: passo 10, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: passo 10, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: passo 10, imagem 3 %32
    • Now that your battery is secured onto the PCB with the cable tie, turn the PCB over and start soldering the battery terminals onto the PCB.
    • After the solder joints have cooled down, cut down the excess part of the battery terminals with a wire cutter.
    • Be careful not to make a short-circuit with the wire cutter or with the terminal wire that will fall off after it will be cut down.
  11. Gamma Scout Geiger Counter Battery Replacement, Installing the PCB back into the case: passo 11, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Installing the PCB back into the case: passo 11, imagem 2 %32
    • After you successfully finished the soldering part, you can start to reassemble the geiger counter.
    • To facilitate the reconnection of the flat-flex cable connector to the pin header of the PCB, you can temporarily remove the front glass protection window of the geiger counter, to be able to maneuver and push the connector onto the pin header.
    • After the connector of the flat-flex cable is firmly connected to the pin header, reinsert the front glass protection window and insert the PCB into the case.
  12. Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: passo 12, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: passo 12, imagem 2 %32 Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: passo 12, imagem 3 %32
    • After the PCB is correctly installed into the front part of the case, close the case carefully by placing the back cover onto it.
    • Insert the three screws into the holes of the back case and screw them in.
    • Because the holes have no metal thread, be careful not to overtighten the screws.
  13. Gamma Scout Geiger Counter Battery Replacement, Resetting the device: passo 13, imagem 1 %32 Gamma Scout Geiger Counter Battery Replacement, Resetting the device: passo 13, imagem 2 %32
    • After you finished the assembly of the case, look for the reset button on the PCB of the geiger counter, located near to the USB port.
    • Push the reset button of the geiger counter with your finger or with a plastic spudger to reset your device to the factory defaults (this step is necessary after battery replacement).
    • Reinsert the USB port cover into the bottom side of the geiger counter.
    • After you set the date and time and configure the datalogging settings, your device is fully functional.
    • Check the battery voltage on the screen of your device.
    • Because geiger counters are test equipments, after a battery replacement you should check the correct function of the device and you should also check the accuracy of the device with a known test source.
Linha de Chegada
5 outras pessoas executaram este guia.
Bela Sajgo
Membro desde: 12/01/19
475 Reputação
Autoria de 1 guia
19Comentários do guia
I blew the tube while replacing the cell and the mica window shattered, it was a mild touch, nothing significant, like a thin paper balloon bursting.
Any idea, where i may buy and new tube? The marking on the tube is LND712.
amitra - Responder
https://www.lndinc.com/products/geiger-m...
Depending on the country you live in, you may also find LND712 geiger tubes from local sellers on Ebay.
Bela Sajgo -
Thanks a lot! Worked as described! Ready again for nuclear war :-(
Ales Tomek - Responder
I’m glad it was useful for you!
Bela Sajgo -
Kedves Béla, nagyon jó guide. Viszont nem bízom magamban. Nem tudná megcsinálni nekem (nyilván nem jótékonysági keretek között)? :-)
Norbert Nagy - Responder
Hello! Elemcserét csinál a gyártó is németországban postai beküldéssel (jelenleg 40 € + áfa + postadíj: https://www.gamma-scout.com/en/repair_in...), de természetesen én is birnák segiteni.
Hello! The manufacturer from Germany also offers a mail-in battery replacement service (at this moment for 40 € + VAT + shipping cost: https://www.gamma-scout.com/en/repair_in...).
Bela Sajgo -
Very detailed and accurate guide, it worked exactly as described. Thank you!
Bela Sajgo -
Ohne Reset bleibt das Display aus. Bei älteren Modellen fehlt die Reset-Taste. Stattdessen kann man durch Kurzschliessen der beiden Lötpunkte RST + DVSS einen Reset durchführen.
(Habe ein Foto gemacht und Punkte markiert; weiß aber nicht, wie ich das Foto hier anhänge).
Ulli601 - Responder
Danke für die Information über die Zurücksetzung bei älteren Modellen! Diese Information könnte für viele nützlich sein.
Thank you for the information about how to reset the older models without a reset button. So after the battery replacement when there is nothing shown on the display, you have to short circuit the RST + DVSS solder points to do a reset.
Bela Sajgo -
Wenn Sie wollen, können Sie mir das Foto per Email zuschicken und ich werde das dann in den Guide einfügen. belasajgo (at) gmail . com - ohne Leerstellen. Aber bitte auch das Originalfoto ohne Markierungen zuschicken, weil die Markierungen aus den obigen Bildern auf der ifixit-Plattform dazugefügt werden, also auch die Markierungen in Ihrem Foto müssten auf der Plattform gemacht werden und nicht vorher.
Bela Sajgo -
Ein Benutzer hat mich kontaktiert weil sein Gamma Scout eine ältere Version mit DB9 ist und nicht nur die Reset-Taste fehlt, sondern auch die Aufschrift mit RST und DVSS. Wie kann man bei dieser Version einen Reset durchführen? Zwei Testpads/Lötpunkte gibt es trotzdem in der Nähe wo normalerweise bei der neueren DB9 Version RST und DVSS waren, aber ich bin mir nicht sicher ob diese die selbe Funktion haben, die Bilder mit der Platine waren nicht klar genug um die Leiterbahnen zu verfolgen. Vielleicht eine Idee dazu?
Bela Sajgo -
My version of the gamma scout has a DB9 connector and no reset switch is visible. It appears to be a much earlier design with soldered-in circuit components added. Perhaps there is a way to do the reset via the DB9 or pads on the board. Any suggestions?
myself - Responder
Another user wrote before a comment about not having a reset button on older versions and that after the battery replacement the display stays off. He also wrote that after the battery replacement when there is nothing shown on the display, you have to short circuit the RST + DVSS solder points on the board to do a reset.
Bela Sajgo -
Thanks a lot for this turorial! It worked out :), however step 6 turned out to be tricky ... the force needed to loosen the connection has to be very strong in regard to the sensitivity of the components. Likewise I could only fullfill step 11 half way without damaging teh cable or other components. Is there any additional hack (I did not have a specific tool).
Grit - Responder
I'm happy that the tutorial was helpful for you. I know that the connector of the flat-flex cable fits very tight onto the pin header and is not easy to put back, I had the same problem. Maybe the pin header was soldered onto the board after it was inserted into the flat-flex connector, in the manufacturing process. Who knows.
Bela Sajgo -
Hi Ulli601, may I have your email so I can send you a picture of the circuit of my old Gamma-Scout, because I am not able to reset it. I would like that you specify which are the solder points to short for the reset. That's because in my circuit the RST + DVSS solder points are not clearly written.
Thanks in advance for your collaboration. Giovanni
GIOVANNI - Responder
is ther a way of upgrading the darn thing to be rechargeble?
Philipp Frey - Responder
Just by replacing the battery with a rechargeable one would not be enough. A charging circuit for the battery would have to be added. But since a new normal lithium battery lasts at least 7-8 years in normal use of the device, I would not find the conversion worth it. Except, if you plan to use the geiger counter constantly for measurements above 10 µSv/h.
Bela Sajgo -
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 117
Ao todo: 8,597
