Ir para o conteúdo principal
Game Boy Pocket LCD Screen Replacement
Adriana Rahrig
Adriana Rahrig e 5 outros colaboradores
Última atualização em January 17, 2025
10 - 20 minutos
Moderado
Despedaçar
Introdução
Ir para o passo 1
If the LCD screen in your Game Boy Pocket is damaged or simply not working and needs replaced, this guide will help you replace and repair your screen. No special skills are required for this replacement. All you need is a small Phillips screwdriver and a plastic opening tool. There is nothing unusual about this repair and it is straightforward.
O que você precisa
Ferramentas
Exibir mais…
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the external screws: passo 1, imagem 3 %32
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
    Where do I find a oem lcd replacement?
    Alex Bone - Responder
  2. Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Open the device: passo 2, imagem 3 %32
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 3 %32
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: passo 5, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: passo 5, imagem 2 %32
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: passo 6, imagem 3 %32
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 1 %32 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 2 %32 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: passo 7, imagem 3 %32
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
    Where did you find a replacement part I need one myself?
    Luis - Responder
Conclusão
19 outras pessoas executaram este guia.
Adriana Rahrig
Membro desde: 10/07/14
1.637 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2014 Membro de USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Membros
Autoria de 19 guias
3Comentários do guia
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Responder
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser -
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik -
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 114
Últimos 30 dias: 515
Ao todo: 27,951
