Introdução
Use this guide to remove the LCD screen from the Game Boy Advance.
O que você precisa
Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
Remove the seven screws securing the back shell:
Six 9.4 mm‑long tri‑point Y0 screws
One 8.5 mm‑long JIS 1 screw
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
Carefully flip the motherboard over the top edge of your Game Boy and rest it on your work surface.
Use tweezers or your fingers to remove the three silicone pads covering the buttons (A and B, the D‑pad, and Start/Select ).
Use tweezers or your fingers to remove the buttons (A and B as well as the D‑pad).
Ferramenta utilizada neste passo:Tweezers$4.99
Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
18 outras pessoas executaram este guia.
