Ir para o conteúdo principal
Game Boy Advance Back Panel Replacement
Aldo Corona
Aldo Corona e 9 outros colaboradores
Última atualização em September 23, 2024
1 - 2 minutos
Fácil
Introdução
Ir para o passo 1
How to remove the back panel from a Game Boy Advance.
O que você precisa
Ferramentas
Exibir mais…
Vídeo de Apresentação
  1. Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 1 %32 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 2 %32 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 3 %32
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: passo 2, imagem 1 %32 Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: passo 2, imagem 2 %32
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Back Panel Replacement, Remove the Back Panel: passo 3, imagem 1 %32
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Conclusão
5 outras pessoas executaram este guia.
Aldo Corona
Membro desde: 01/25/10
871 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membros
Autoria de 62 guias
1Comentário do guia
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
Renzo Guichelaar - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 95
Ao todo: 11,574
