Game Boy Advance Back Panel Replacement
Introdução
Ir para o passo 1How to remove the back panel from a Game Boy Advance.
O que você precisa
Vídeo de Apresentação
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
4 outras pessoas executaram este guia.
1Comentário do guia
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
