Ir para o conteúdo principal
Fujifilm FinePix Z90 LCD Screen Replacement
Sam Clark
Sam Clark e 3 outros colaboradores
Última atualização em May 6, 2020
10 - 30 minutos
Difícil
Introdução
Ir para o passo 1
If you are experiencing dead pixels, scratches, a broken screen, or general unresponsiveness of the touch screen it can indicate the need for replacement. Replacing the LCD screen on your Fujifilm FinePix Z90 is the best option when such damage occurs preventing any response from touch screen. This guide is to aid in the replacement of the LCD screen when necessary.
O que você precisa
Ferramentas
Exibir mais…
  1. Fujifilm FinePix Z90 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Fujifilm FinePix Z90 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Locate the right side of the camera, where the USB connector is. Remove uncovered Phillips #000 screw.
    • Once the uncovered screw is removed, open the USB connector cover to remove the next Phillips #000 screw.
  2. Fujifilm FinePix Z90 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the two uncovered Phillips #000 screws from the left side.
    • Repeat for the screws on the bottom.
  3. Fujifilm FinePix Z90 LCD Screen Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 3, imagem 2 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 3, imagem 3 %32
    • Remove the casing from the back of camera where LCD screen is located.
    • On the right side of the camera locate the wrist strap. Carefully remove the lace that attached wrist strap to camera.
    • Located just above (or next to) lace that attaches wrist strap is a ribbon cable. Be extremely cautious not to tear when removing lace. This ribbon connects the front panel to the motherboard.
    • Gently remove silver piece that lace was connected to, set aside.
  4. Fujifilm FinePix Z90 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 4, imagem 2 %32
    • After removing silver piece that attached to lace, locate and remove screw.
    • Turning camera back to the LCD screen, remove the three screws just to the right of screen. These are located next to the ribbon cables attaching the LCD to the motherboard.
  5. Fujifilm FinePix Z90 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently remove front of camera face (casing).
    • Once removed motherboard should be displayed. Be very careful with this section.
  6. Fujifilm FinePix Z90 LCD Screen Replacement: passo 6, imagem 1 %32
    • Using a plastic opening tool, pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is another ribbon cable attaching the LCD screen to the motherboard; be careful not to tear it. Be sure to tear black electrical tape before removing ribbon.
  7. Fujifilm FinePix Z90 LCD Screen Replacement: passo 7, imagem 1 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 7, imagem 2 %32 Fujifilm FinePix Z90 LCD Screen Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, flip open the black lever to release the ribbon.
    • Gently slide the cable out of the lock; the LCD screen is now ready to be removed.
Conclusão
Once you have removed the damaged screen, following the instructions in reverse order will instruct you to reassemble your device.
Sam Clark
Membro desde: 11/03/15
301 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 Membro de UMass Dartmouth, Team 1-6, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G6
2 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 1,173
