Ir para o conteúdo principal
Fujifilm FinePix XP80 Speaker Replacement
Amanda Lewis
Amanda Lewis e 6 outros colaboradores
Última atualização em May 3, 2020
45 minutos - 1 hora
Difícil
Introdução
Ir para o passo 1
Learn how to replace the speaker in a Fujifilm FinePix XP80 camera.
Please note: this guide requires soldering. For more information, see the Soldering Guide.
O que você precisa
Ferramentas
Exibir mais…
  1. Fujifilm FinePix XP80 Speaker Replacement, Battery: passo 1, imagem 1 %32 Fujifilm FinePix XP80 Speaker Replacement, Battery: passo 1, imagem 2 %32 Fujifilm FinePix XP80 Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Speaker Replacement: passo 2, imagem 1 %32
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Speaker Replacement, Exterior Case: passo 3, imagem 1 %32
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Speaker Replacement: passo 4, imagem 1 %32
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Speaker Replacement: passo 5, imagem 1 %32
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Speaker Replacement: passo 6, imagem 1 %32
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Speaker Replacement: passo 7, imagem 1 %32
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Speaker Replacement: passo 8, imagem 1 %32
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Speaker Replacement: passo 9, imagem 1 %32 Fujifilm FinePix XP80 Speaker Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Speaker Replacement, Interior Case: passo 10, imagem 1 %32
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Speaker Replacement: passo 11, imagem 1 %32
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Speaker Replacement: passo 12, imagem 1 %32
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Speaker Replacement: passo 13, imagem 1 %32 Fujifilm FinePix XP80 Speaker Replacement: passo 13, imagem 2 %32 Fujifilm FinePix XP80 Speaker Replacement: passo 13, imagem 3 %32
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Speaker Replacement: passo 14, imagem 1 %32
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Speaker Replacement, Speaker: passo 15, imagem 1 %32 Fujifilm FinePix XP80 Speaker Replacement, Speaker: passo 15, imagem 2 %32
    • Carefully remove the black sticker covering the motherboard.
  16. Fujifilm FinePix XP80 Speaker Replacement: passo 16, imagem 1 %32
    • Using a PH000 Phillips bit, remove the four screws shown.
  17. Fujifilm FinePix XP80 Speaker Replacement: passo 17, imagem 1 %32
    • Using a plastic opening tool, carefully remove the lens housing to the left of the motherboard.
  18. Fujifilm FinePix XP80 Speaker Replacement: passo 18, imagem 1 %32
    • Peel back the sticker on the side of the motherboard.
    • Using a PH000 Phillips bit, remove the screw.
  19. Fujifilm FinePix XP80 Speaker Replacement: passo 19, imagem 1 %32 Fujifilm FinePix XP80 Speaker Replacement: passo 19, imagem 2 %32
    • Using a PH000 Phillips bit, remove the screw shown.
    • Unclip the three ribbon cables that are still attached to the motherboard.
    • Use the plastic opening tool to gently pry the motherboard loose.
    • Move the motherboard aside slightly to reveal the speaker, which is connected to the motherboard by red and black wires.
  20. Fujifilm FinePix XP80 Speaker Replacement: passo 20, imagem 1 %32
    • Lift the motherboard out of the way, being careful of the speaker wires.
    • Carefully pry the speaker out of its slot in the case.
  21. Fujifilm FinePix XP80 Speaker Replacement: passo 21, imagem 1 %32
    • To remove the speaker from the motherboard, desolder its connection.
    • For instructions on desoldering, see the following guide: Como soldar e dessoldar contatos
Conclusão
Amanda Lewis
Membro desde: 09/25/16
317 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Cagle Fall 2016 Membro de USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Membros
Autoria de 14 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 305
