Fujifilm FinePix T500 Shutter and Power Button Circuit Board Replacement
Introdução
Vá para o passo 1If the buttons on your Fujifilm FinePix T500 camera are unresponsive, the issue may be with the circuit board. Replacing the circuit board can restore functionality, but it requires careful handling of small components. Before you begin, make sure you have the necessary tools, such as a Phillips #00 screwdriver, spudger, soldering iron, and tweezers. Be cautious when working with internal electronics, as improper handling can cause further issues. Follow this step-by-step guide to safely complete the repair
O que você precisa
Ferramentas
Exibir mais…
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to pull back the plastic covering the top of the camera.
Desolder the red, black, and white wires from the circuit board that you pried off earlier.
