FujiFilm FinePix S4500 Flash Springs Replacement
Introdução
Ir para o passo 1The springs in your flash mechanism may break or become worn out. If this happens, follow these steps to replace them.
O que você precisa
Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
Remove the 3.5 mm Phillips #1 screws holding the top to allow access to the flash mechanism.
