Fitting Ski Bindings to a New Pair of Boots
Introdução
Vá para o passo 1Use this guide to adjust ski bindings to fit a new skier. It applies to alpine ski only, not to cross-country ski.
The ski binding is the device that connects your ski boot to the ski. When a skier gets a new pair of ski boots or buys the sky of someone else, it’s unnecessary to purchase a new pair of skis or pay someone to adjust the bindings. Instead, you can use this guide to learn how to adjust the bindings yourself.
This guide shows you how to adjust the location of the bindings as well as the DIN setting. Your DIN setting is a function of your height, weight, and a few other personalized parameters. It’s crucial to adjust it for your security and ease.
Before using this guide, calculate your DIN setting here.
O que você precisa
Locate the boot size (in millimeters) on the bottom of the boot.
Repeat this guide on the other ski and you’re ready to go!
4 outras pessoas executaram este guia.
4 comentários
Super Anleitung, vielen Dank. Das erspart mir eine Fahrt quer durch die Stadt zum Sportgeschäft!
Kürzer und klarer geht es nicht. Alle horizontalen und vertikalen Fragen sind beantwortet. Danke
