Ir para o conteúdo principal
Fitting Ski Bindings to a New Pair of Boots
Veronica Contreras
Veronica Contreras e 5 outros colaboradores
Última atualização em February 14, 2024
10 - 20 minutos
Moderada
Guia do aluno destaque
Use this guide to adjust ski bindings to fit a new skier. It applies to alpine ski only, not to cross-country ski.
The ski binding is the device that connects your ski boot to the ski. When a skier gets a new pair of ski boots or buys the sky of someone else, it’s unnecessary to purchase a new pair of skis or pay someone to adjust the bindings. Instead, you can use this guide to learn how to adjust the bindings yourself.
This guide shows you how to adjust the location of the bindings as well as the DIN setting. Your DIN setting is a function of your height, weight, and a few other personalized parameters. It’s crucial to adjust it for your security and ease.
Before using this guide, calculate your DIN setting here.
  1. Fitting Ski Bindings to a New Pair of Boots, Fitting Ski Bindings to a New Pair of Boots: passo 1, imagem 1 %32
    • Locate the boot size (in millimeters) on the bottom of the boot.
    • If the boot size is not on the bottom, check the inner or outer sides of the heel.
    • In our case, the size is 316mm. However, this may not be the case for everyone.
  2. Fitting Ski Bindings to a New Pair of Boots: passo 2, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 2, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 2, imagem 3 %32
    • Place your ski on a flat surface with the ski bindings facing up.
    • Locate the lever on the side of the heel piece of the binding.
    • Lift and hold the lever in the upright position.
  3. Fitting Ski Bindings to a New Pair of Boots: passo 3, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 3, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 3, imagem 3 %32
    • With the lever raised, slide the heel piece until the markers point to the correct range of the boot size.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 311mm - 318mm. This may not be the case for everyone.
  4. Fitting Ski Bindings to a New Pair of Boots: passo 4, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 4, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 4, imagem 3 %32
    • Locate the lever on the toe piece of the binding.
  5. Fitting Ski Bindings to a New Pair of Boots: passo 5, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 5, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 5, imagem 3 %32
    • With the lever raised, slide the toe piece until the markers point to the correct boot size range.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 315mm - 322mm. This may not be the case for everyone.
  6. Fitting Ski Bindings to a New Pair of Boots: passo 6, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 6, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 6, imagem 3 %32
    • Insert the toe of the boot into the toe piece of the binding.
    • Push down on the boot until the boot clips into the binding. If needed, you can lift the lever on the heel piece to facilitate the procedure.
  7. Fitting Ski Bindings to a New Pair of Boots: passo 7, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 7, imagem 2 %32
    • Insert the screwdriver in the front of the toe piece.
    • Loosen the screw until the toe bar moves backwards.
    • You should be able to fit a piece of paper between the bottom of the boot and the toe bar.
  8. Fitting Ski Bindings to a New Pair of Boots: passo 8, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 8, imagem 2 %32
    • Insert a piece of paper between the bottom of the boot and the toe bar.
    • Tighten the screw at the front of the toe piece until there is resistance when pulling the paper out.
    • You should be able to pull the paper out without it ripping but not push it back in.
    • Over-tightening of the toe bar can be dangerous. Practice caution and take your time.
  9. Fitting Ski Bindings to a New Pair of Boots: passo 9, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 9, imagem 2 %32
    • Adjust the DIN setting on the toe piece to your personalized setting by tightening or loosening the screw on the side of the bindings.
    • Look at the window on the top of the toe piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous, because the bidding won't be activated if the ski is subject to high strains. Use caution to not over-tighten the screw. On the contrary, a low value will cause undesired activations of the binding, which can be dangerous, too.
  10. Fitting Ski Bindings to a New Pair of Boots: passo 10, imagem 1 %32 Fitting Ski Bindings to a New Pair of Boots: passo 10, imagem 2 %32 Fitting Ski Bindings to a New Pair of Boots: passo 10, imagem 3 %32
    • Repeat step 9 but on the heel piece.
    • Adjust the DIN setting on the heel piece by tightening or loosening the screw on the back.
    • Look at the window on the top of the heel piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous. Use caution to not over-tighten the screw.
Conclusão
Repeat this guide on the other ski and you’re ready to go!
4 outras pessoas executaram este guia.
Equipe
UC Davis, Team S1-G3, Andersen Winter 2020 Membro de UC Davis, Team S1-G3, Andersen Winter 2020
UCD-ANDERSEN-W20S1G3
Membros da 4
Autoria de 5 guias
4 comentários
Super Anleitung, vielen Dank. Das erspart mir eine Fahrt quer durch die Stadt zum Sportgeschäft!
Joerg Schnur - Responder
Kürzer und klarer geht es nicht. Alle horizontalen und vertikalen Fragen sind beantwortet. Danke
Andreas Rothe - Responder
Sehr gute Anleitung auch für Anfänger.
Tuzzer 2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 46
Últimos 7 dias: 472
Últimos 30 dias: 2,781
Duração total: 103,608
