Fitbit Surge Screen Replacement
Introdução
Ir para o passo 1Is your Fitbit Surge screen damaged? Read this guide to learn how to replace the LCD screen. Keep in mind that the wristband will need to be cut for this guide and it cannot be reattached.
O que você precisa
Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
Please note that the band cannot be reattached as it must be cut in order to replace the screen.
5 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all7Comentários do guia
Is the outer glass and screen two separate parts? If so where can I get the assembly for the outermost glass? Is the touchscreen portion of the watch the LCD itself or the outer screen? I have been searching endlessly for that part or directions on how to replace it.
I took my apart because there was condensation under the touch screen. While doing this I found that there are several modifications to these steps.
1. Use a Philips PH00 as its a better fit.
2. Don’t cut the band. I was able to use a thin spudger to pry around it and get it off. If you do need to replace the band you can find one on Amazon.
3. Don’t scrape away the adhesive; you need that to re-attach the band. You may need to move some of it but you don't need to scrape it clean.
4. At step 5 I found it better to push in the single button and then pry the outer gray casing off. The buttons didn’t appear to remove after the casing was removed.
5. Before step 6: There are 4 clasps that are holding the top and bottom parts together. Those need to be removed before you can pry it open.
This is a nice advertisement for minture tools but we need to locate a source for replacement screens…….not screen protectors.
All the tools in the world are useless if you have no screen……no screen no need for tools.
So, where can replacement screens be sourced for the Fitbit Surge
Check this this IFIXIT link for information on sourcing a new screen: FitBit Surge Teardown
Specific details:
I clicked on the link for the screen tech sheet. At the end is a link to where you can buy a new screen:
https://www.mouser.com/ProductDetail/Sha...
Price for 1 is 13.80 USD
This was an amazing tutorial and saved me so much money!!!
