Ir para o conteúdo principal
Fender Starcaster String Replacement
Jasper Fleischhauer
Jasper Fleischhauer
Última atualização em October 13, 2016
5 minutos
Fácil
Precisa de melhores imagens
Introdução
Ir para o passo 1
There are many different styles of tuners and bridges, therefore, many different methods of replacing the strings. This Starcaster has a string-through bridge and standard in-line tuners, so the string changing process is fairly simple.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Fender Starcaster String Replacement, Loosen the Strings: passo 1, imagem 1 %32 Fender Starcaster String Replacement, Loosen the Strings: passo 1, imagem 2 %32 Fender Starcaster String Replacement, Loosen the Strings: passo 1, imagem 3 %32
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: passo 2, imagem 1 %32 Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: passo 2, imagem 2 %32
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, imagem 1 %32 Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, imagem 2 %32 Fender Starcaster String Replacement, Remove the Strings from the Bridge: passo 3, imagem 3 %32
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    When I cut 4-6 winding string, I have experience with the metal piece of the string entering my eyeball.
    It is recommended to wear goggles or cut with eyes closed.
    Takehiro - Responder
  4. Fender Starcaster String Replacement, String: passo 4, imagem 1 %32 Fender Starcaster String Replacement, String: passo 4, imagem 2 %32 Fender Starcaster String Replacement, String: passo 4, imagem 3 %32
    • Take any one of the new strings and slide it through the appropriate bridge hole.
    • The replacement strings used on this guitar were "Regular Slinky" by Ernie Ball, which is a 10 gauge string set.
    • 6th String: E - 46 Gauge
    • 5th String: A - 36 Gauge
    • 4th String: D - 26 Gauge
    • 3rd String: G - 17 Gauge
    • 2nd String: B - 13 Gauge
    • 1st String: E - 10 Guage
  5. Fender Starcaster String Replacement: passo 5, imagem 1 %32 Fender Starcaster String Replacement: passo 5, imagem 2 %32 Fender Starcaster String Replacement: passo 5, imagem 3 %32
    • Lay the string parallel to the guitar's neck and directly over the appropriate tuning peg.
    • Measure a "three finger's length" (about 1.5") on the string passed the tuning peg.
    • Make a sharp bend in the string at where you measured 1.5" passed the tuning peg.
    • Turn the tuning peg until the string hole faces perpendicular to the guitar's neck.
    • Feed the bent string into the tuning peg until the bend meets the tuning post.
  6. Fender Starcaster String Replacement: passo 6, imagem 1 %32 Fender Starcaster String Replacement: passo 6, imagem 2 %32 Fender Starcaster String Replacement: passo 6, imagem 3 %32
    • Make another sharp bend in the string on the outside of the tuning post.
    • Turn the tuning key counter clockwise while applying light pressure to the string on the inside of the post.
    • Wrapping the string around the post will help the string stay in-tune longer.
    • If the wraps of the string around the post start to roll over the top of the post, hold them down while still turning the post.
    • Continue turning the post until at least 2 full wraps of the string have been made around the post.
  7. Fender Starcaster String Replacement: passo 7, imagem 1 %32 Fender Starcaster String Replacement: passo 7, imagem 2 %32
    • Snip the excess string off from the post with a wire cutter (leaving at least half an inch of string left).
  8. Fender Starcaster String Replacement: passo 8, imagem 1 %32 Fender Starcaster String Replacement: passo 8, imagem 2 %32 Fender Starcaster String Replacement: passo 8, imagem 3 %32
    • Continue installing strings using the the same method described in the last few steps.
    • The last four strings (the D, G, B, and E strings), must be guided underneath the two "string trees" in the center of the headstock.
    • String Tree for the D and G strings
    • String Tree for the B and E strings
    • Tune the strings to your desired pitch and your guitar is ready to play!
Conclusão
3 outras pessoas executaram este guia.
Jasper Fleischhauer
Membro desde: 10/20/14
35.030 Reputação
Autoria de 2 guias
1Comentário do guia
Good guide very helpful.
Neo kramer - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 6,208
