Fast Fix Screen Replacement
Introdução
Ir para o passo 1This guide can be used to remove and replace a screen on a Dell Insprion 15-3521. The tools needed are a small Phillips screwdriver, and a small flat screwdriver or like prying device.
O que você precisa
Peças
Ferramentas
Exibir mais…
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all2Comentários do guia
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
Hi, Did you ever fix this problem? I'm having the same issue.
