Ir para o conteúdo principal
Fahrenheit FHT 125PRMR Motherboard Replacement
O que você precisa
    1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
      • Remove both hinge covers on each side of the flat iron.
      Pergunte ao FixBot
      Comentar
    2. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 2, imagem 1 %32
      • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
      Pergunte ao FixBot
      Comentar
    3. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 3, imagem 1 %32 Fahrenheit FHT 125PRMR Motherboard Replacement: passo 3, imagem 2 %32
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      Pergunte ao FixBot
      Comentar
    4. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 4, imagem 1 %32 Fahrenheit FHT 125PRMR Motherboard Replacement: passo 4, imagem 2 %32
      • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
      Pergunte ao FixBot
      Comentar
    5. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 5, imagem 1 %32
      • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
      Pergunte ao FixBot
      Comentar
    6. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 6, imagem 1 %32 Fahrenheit FHT 125PRMR Motherboard Replacement: passo 6, imagem 2 %32
      • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
      Pergunte ao FixBot
      Comentar
    7. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 7, imagem 1 %32
      • Remove the covering panel by pulling up with your hand.
      Pergunte ao FixBot
      Comentar
    8. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 8, imagem 1 %32 Fahrenheit FHT 125PRMR Motherboard Replacement: passo 8, imagem 2 %32
      • Remove three 3 mm sliver screws #1 from the motherboard.
      • Use your hand to life the motherboard out of the flat iron.
      Pergunte ao FixBot
      Comentar
    9. Fahrenheit FHT 125PRMR Motherboard Replacement: passo 9, imagem 1 %32
      Pergunte ao FixBot
      Comentar
Conclusão
MeKenzie Hilsmeyer
Membro desde: 09/29/16
23 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Harley Fall 2016 Membro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 1,966
