Dyson Supersonic HD01 Buttons Replacement
Introdução
Ir para o passo 1This guide shows how to replace the power button and cold shot button on the Dyson Supersonic HD01. When the buttons are dirty or have a foreign object stuck inside them, they will not work properly. If the buttons on your hairdryer are jammed, this guide will help ensure buttons that work.
You may consider cleaning the buttons of debris after removing it.
O que você precisa
Heat the iOpener in the microwave for 30 seconds and apply it immediately to the top of the buttons.
Leave the iOpener in place for a couple minutes.
Ferramenta utilizada neste passo:Microfiber Cleaning Cloths$3.99
Remove the buttons with tweezers.
Power button
Cold shot button
2Comentários do guia
My Dyson Supersonic will start but nor heat up. Called the company but guarantee expired by 3 months. They won't fix it.
Is there a chance to check inside and try to repair? Thanks.
as far as I know only counterfit supersonics fail in that way. I had one of those. The inrush current limiter basically exploded. (because the part is sized way too small for the current in a hair dryer). Real dysons usually stop working alltogether because the thermal fuse blew.
