Ir para o conteúdo principal
DualShock 4 CHU-ZCT2U Charging Port Replacement
David Seale
David Seale e 7 outros colaboradores
Última atualização em May 7, 2024
25 minutos
Moderada
Melhor Introdução
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
This guide will show you how to disassemble your DualShock 4 CHU-ZCT2U controller and access the charging port for replacement.
  1. DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement, Outer Shell: passo 1, imagem 3 %32
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: passo 3, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement, Charging Port: passo 3, imagem 2 %32
    • Pull the ribbon cable from the charge port, using a set of tweezers.
  4. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 4, imagem 3 %32
    • Grip the right hand corner of the opaque white piece with a pair of tweezers, and pull it upwards to remove it.
  5. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 5, imagem 3 %32
    • Lift the clear plastic piece up by its right hand corner.
    • Pull it to the right to remove the bottom left hand corner from the groove.
    • Remove the clear plastic piece. It pushes in easily.
  6. DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, imagem 1 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, imagem 2 %32 DualShock 4 CHU-ZCT2U Charging Port Replacement: passo 6, imagem 3 %32
    • Peel off the black sticker on the charge port, using a pair of tweezers.
    • Unscrew the 4.50mm screw in the center of the port chip, using a Phillips-Head screwdriver.
    • Pull the charging port out with a pair of tweezers.
Conclusão
16 outras pessoas executaram este guia.
David Seale
Membro desde: 10/09/17
1.714 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2017 Membro de USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
Membros da 3
Autoria de 28 guias
9 comentários
Came in handy, since it’s hard enough to fix a JDM-030. Thanks!
Sunset Shimmer - Responder
Just did this on my JDM-030 (3rd generation DS4) as well. I would point out that the charge port for the JDM-030 (JDS-030?) looks slightly different and has more of a T-shape than the JDS-040, but aside from that, the instructions are functionally the same.
I will lastly add that having good tweezers is a must: the tweezers my jeweler’s drivers came with were crap and I had to go to the store to buy another pair. Make sure your equipment is solid before assembly.
Rob Barba - Responder
Can The JDS 040 work in a controller that uses the JDS 030?
RandyH - Responder
Tried to replace my usb port with a board that reads “1-981-33-31” from amazon. It was listed as JDS-40 and it does not work. In fact when plugged into a usb port on my laptop the ribbon cable gets noticeably hot but the controller will not power on.
Devin Sidell - Responder
Got the same problem. Any idea?
Jacco Veldscholten -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 13,284
