Ir para o conteúdo principal
Drobo FS DRDS2-A Power Switch Replacement
Rye Cassan
Rye Cassan e 3 outros colaboradores
Última atualização em September 7, 2021
15 minutos
Moderado
Introdução
Ir para o passo 1
How to replace the Power Switch
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Drobo FS DRDS2-A Power Switch Replacement, Case: passo 1, imagem 1 %32
    • To start getting the case off remove the front panel so it's out of the way.
  2. Drobo FS DRDS2-A Power Switch Replacement: passo 2, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement: passo 2, imagem 2 %32
    • Next remove the screws from the feet of the case with a phillips head screwdriver.
  3. Drobo FS DRDS2-A Power Switch Replacement: passo 3, imagem 1 %32
    • To remove the case, place the Drobo on its back and slide the case off.
  4. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, imagem 2 %32 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: passo 4, imagem 3 %32
    • Press tabs to release back cover and lift off
  5. Drobo FS DRDS2-A Power Switch Replacement: passo 5, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement: passo 5, imagem 2 %32
    • Push tabs in and carefully pull out the front facer and drive shelves
  6. Drobo FS DRDS2-A Power Switch Replacement: passo 6, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement: passo 6, imagem 2 %32
    • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
    • If you have a Drobo 5N2, you may also need to remove the 3 screws on each side.
  7. Drobo FS DRDS2-A Power Switch Replacement: passo 7, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement: passo 7, imagem 2 %32
    • Carefully unplug the Power Switch and Fan wires.
  8. Drobo FS DRDS2-A Power Switch Replacement: passo 8, imagem 1 %32
    • Press tabs on Power Switch to release the Power Switch and Push out.
    • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
  9. Drobo FS DRDS2-A Power Switch Replacement: passo 9, imagem 1 %32 Drobo FS DRDS2-A Power Switch Replacement: passo 9, imagem 2 %32
    • Finally pull the old switch out and pop the new one in.
Conclusão
3 outras pessoas executaram este guia.
Rye Cassan
Membro desde: 01/24/17
182 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-4, Banghart Winter 2017 Membro de Cal Poly, Team 10-4, Banghart Winter 2017
CPSU-BANGHART-W17S10G4
3 Membros
Autoria de 5 guias
5Comentários do guia
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - Responder
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - Responder
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - Responder
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
John W - Responder
Many thanks Rye. My Drobo 5C switch has been playing up for a while and your article gave me the courage to tackle the issue. A few dirfferences for the 5C (removing the back panel) but otherwise all tickety boo.
Maarten van der Kleij - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 2,375
