Ir para o conteúdo principal
Door Mirror Replacement
O que você precisa
  1. Door Mirror Replacement, Door Mirror: passo 1, imagem 1 %32
    • Use a screwdriver to remove the two brackets securing the top of the mirror.
    • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
    • The type of screwdriver needed will depend on your specific brackets.
  2. Door Mirror Replacement: passo 2, imagem 1 %32
    • Lift the broken mirror off of the door.
    • Remove any cardboard or other cushioning (if any) from the door.
  3. Door Mirror Replacement: passo 3, imagem 1 %32
    • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
  4. Door Mirror Replacement: passo 4, imagem 1 %32
    • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
  5. Door Mirror Replacement: passo 5, imagem 1 %32
    • Replace any cushioning behind the mirror.
    • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
  6. Door Mirror Replacement: passo 6, imagem 1 %32
    • Replace the top brackets and tighten them to full secure the mirror.
Conclusão
Enjoy your new mirror!
Seth Wanderman
Membro desde: 02/28/22
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 409
