Ir para o conteúdo principal
Door Handle Doorknob Replacement
amy pantoja
amy pantoja e um outro colaborador
Última atualização em May 14, 2024
5 minutos
Muito fácil
Guia colaborativo
  1. Door Handle Doorknob Replacement, How to Change an Indoor Doorknob Handle: passo 1, imagem 1 %32
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. Door Handle Doorknob Replacement: passo 2, imagem 1 %32
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. Door Handle Doorknob Replacement: passo 3, imagem 1 %32
    • Unscrew both long screws.
  4. Door Handle Doorknob Replacement: passo 4, imagem 1 %32
    • Remove the door knob on both sides of the door.
  5. Door Handle Doorknob Replacement: passo 5, imagem 1 %32
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. Door Handle Doorknob Replacement: passo 6, imagem 1 %32
    • Unscrew the two short screws on the latch face plate.
  7. Door Handle Doorknob Replacement: passo 7, imagem 1 %32
    • Remove the latch face plate and latch mechanism.
  8. Door Handle Doorknob Replacement: passo 8, imagem 1 %32
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. Door Handle Doorknob Replacement: passo 9, imagem 1 %32
    • Screw in both short screws of the latch face plate.
  10. Door Handle Doorknob Replacement: passo 10, imagem 1 %32
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. Door Handle Doorknob Replacement: passo 11, imagem 1 %32
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. Door Handle Doorknob Replacement: passo 12, imagem 1 %32
    • Screw in both long screws on both sides of the door knob.
  13. Door Handle Doorknob Replacement: passo 13, imagem 1 %32
    • Turn the door knob to test your work.
    • Gather your tools: A new doorknob set, drill, screwdriver
    • Unscrew the screws on the recent knob and once unscrewed you may know take out the knob from the door.
    • Takeout and install the new latch: Unscrew the latch assembly and remove the latch mechanism from the door. Then insert the new latch into the hole making sure it is facing the right way.
    • Next you will be placing the exterior knob on the outside and the interior inside and will secure the screws.
    • Check if the latch properly works and make sure the door open and closes.
Conclusão
amy pantoja
Membro desde: 05/04/24
121 Reputação
Autoria de 1 guia
1Comentário do guia
Why can I not find an interior door knob set that doesn’t have a plate on the latch assembly?
Bob - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 235
