Ir para o conteúdo principal
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
Daniel Kresge
Daniel Kresge e 4 outros colaboradores
Última atualização em May 10, 2020
10 minutos
Moderado
Introdução
Ir para o passo 1
The VTech has two cases. The main case housing the main circuit board and other components and a smaller enclosure that houses the screen and two buttons. This guide is how to disassemble the Vtech to gain access to the screen and button components.
O que você precisa
Ferramentas
Exibir mais…
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: passo 1, imagem 1 %32
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, imagem 2 %32
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, imagem 2 %32
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, imagem 1 %32
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 5, imagem 1 %32
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 6, imagem 1 %32
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 7, imagem 1 %32
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
Conclusão
Daniel Kresge
Membro desde: 09/01/15
385 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
1Comentário do guia
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 2,187
