Ir para o conteúdo principal
Desktop PC RAM Replacement
David Lennon
David Lennon e 5 outros colaboradores
Última atualização em April 6, 2023
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
RAM(Random Access Memory) is a very fast type of memory. It stores short term information so that it can be accessed quickly. Replacing or upgrading RAM in a computer can help a computer run more quickly and smoothly.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Desktop PC RAM Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Responder
    This is correct.
    DistroHopper39B -
  2. Desktop PC RAM Replacement: passo 2, imagem 1 %32 Desktop PC RAM Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: passo 3, imagem 1 %32
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: passo 4, imagem 1 %32
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
Conclusão
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.108 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 45 guias
4 comentários
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Responder
how to determine the speed
benzy aceware - Responder
how can i differentiate between types of rams
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 104
Ao todo: 7,622
