Ir para o conteúdo principal
Desktop PC RAM Replacement
O que você precisa
  1. Desktop PC RAM Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: passo 2, imagem 1 %32 Desktop PC RAM Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: passo 3, imagem 1 %32
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: passo 4, imagem 1 %32
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
Conclusão
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
50 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
9.713 Reputação
10 Guias de autoria
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
35 Guias de autoria
4 comentários
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Responder
how to determine the speed
benzy aceware - Responder
how can i differentiate between types of rams
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 81
Duração total: 6,531
