Ir para o conteúdo principal
Desktop PC Hard Drive Replacement
Rubin Girling
Rubin Girling e 6 outros colaboradores
Última atualização em April 6, 2023
15 minutos
Moderado
Introdução
Ir para o passo 1
Hard drives store most of the information on a computer. The hard drive of a computer must be replaced if the computer crashes. Hard drive replacement is an important skill for desktop PC users.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Desktop PC Hard Drive Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Responder
    This is correct.
    DistroHopper39B -
  2. Desktop PC Hard Drive Replacement: passo 2, imagem 1 %32 Desktop PC Hard Drive Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Hard Drive Replacement, Right Panel: passo 3, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
  4. Desktop PC Hard Drive Replacement: passo 4, imagem 1 %32 Desktop PC Hard Drive Replacement: passo 4, imagem 2 %32
    Not always necessary to do this step.
    Scott Sinclair - Responder
  5. Desktop PC Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
  6. Desktop PC Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
  7. Desktop PC Hard Drive Replacement: passo 7, imagem 1 %32
    • Slide the hard drive out from the metal casing.
    En glissant le disque dur, faire attention à ne pas accrocher un des fils venant du boitier vers la carte mère. Les fils du Power panel notamment.
    benam - Responder
  8. Desktop PC Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the cables from the back of the hard drive.
    Perso, je retire les câble avant de retirer le disque dur.
    benam - Responder
Conclusão
61 outras pessoas executaram este guia.
Rubin Girling
Membro desde: 04/14/15
736 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 45 guias
2Comentários do guia
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - Responder
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 33
Últimos 30 dias: 163
Ao todo: 10,081
