Ir para o conteúdo principal
Desktop PC GPU Replacement
Joseph Thompson
Joseph Thompson e 2 outros colaboradores
Última atualização em March 19, 2025
35 minutos
Fácil
Guia colaborativo
O que você precisa
Ferramentas
Exibir mais…
  1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: passo 1, imagem 1 %32
    • Minimize exposure to items that can charge up and produce static electricity.
    • Use an anti-static wrist band.
  2. Desktop PC GPU Replacement, Turn Off Computer: passo 2, imagem 1 %32
    • Power off PC via Windows.
    • Switch off Power Supply
  3. Desktop PC GPU Replacement, Unscrew Case Side Panel: passo 3, imagem 1 %32 Desktop PC GPU Replacement, Unscrew Case Side Panel: passo 3, imagem 2 %32
    • Put screws where you wont lose them
  4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: passo 4, imagem 1 %32
    • Be gentle to not pull with to much force when removing power cables.
  5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: passo 5, imagem 1 %32
    • Try not to touch other components.
    • Gently pull the card out of the slot.
  6. Desktop PC GPU Replacement, Insert New GPU: passo 7, imagem 1 %32
    • Verify that the notch in the connector matches the motherboard before sliding in.
    • Carefully slide in GPU until you hear a click on the motherboard.
  7. Desktop PC GPU Replacement, Connect Power Cables: passo 8, imagem 1 %32
    • Insert wisdom here.
  8. Desktop PC GPU Replacement, Re-Attach Side Panel: passo 9, imagem 1 %32
    • Use same screws from step 2.
    • Flip power supply switch back to on.
    • Plug in PC and turn on.
    • If PC does not post go back through the steps to see if you missed something.
    • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
    • Enjoy your new GPU.
Conclusão
Uma outra pessoa concluiu este guia.
Joseph Thompson
Membro desde: 06/20/19
235 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 89
Ao todo: 847
