Ir para o conteúdo principal
Dell XPS 15 9570 SSD Replacement
Baidullah Hazrat
Baidullah Hazrat e 2 outros colaboradores
Última atualização em April 23, 2025
6 minutos
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
Use this guide to remove the SSD card in your Dell XPS 15 9570. An SSD, or solid state drive, is a type of computer storage device that uses electronic circuits to store and retrieve data. Unlike traditional hard disk drives (HDDs), SSDs have no moving parts, which makes them faster, quieter, more durable, and more energy-efficient. When an SSD stops working it may be impossible to store data into it. Before replacing an SSD, it's important to back up any important data that is stored on the drive. This is because replacing an SSD typically involves removing the old drive and installing a new one, which can result in the loss of any data stored on the old drive. Before continuing, ensure that your laptop is totally powered off and disconnected from any external power source.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell XPS 15 9570 SSD Replacement, Base Cover: passo 1, imagem 1 %32
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 SSD Replacement: passo 2, imagem 1 %32 Dell XPS 15 9570 SSD Replacement: passo 2, imagem 2 %32 Dell XPS 15 9570 SSD Replacement: passo 2, imagem 3 %32
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 SSD Replacement: passo 3, imagem 1 %32 Dell XPS 15 9570 SSD Replacement: passo 3, imagem 2 %32
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 SSD Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 SSD Replacement, SSD: passo 5, imagem 1 %32 Dell XPS 15 9570 SSD Replacement, SSD: passo 5, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  6. Dell XPS 15 9570 SSD Replacement: passo 6, imagem 1 %32 Dell XPS 15 9570 SSD Replacement: passo 6, imagem 2 %32
    • Using your hands, hold the SSD and slightly pull to the left.
Conclusão
Baidullah Hazrat
Membro desde: 02/21/23
85 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 77
Ao todo: 2,098
