Ir para o conteúdo principal
Dell XPS 15 9500 SSD Replacement
Bryan Chung
Bryan Chung e 3 outros colaboradores
Última atualização em November 15, 2022
15 - 25 minutos
Moderado
Introdução
Ir para o passo 1
This guide will show the steps required to replace the M.2 SSD on a Dell XPS 15 9500. The M.2 SSD is used to store data and the operating system on this laptop. You may want to follow this guide if you are having trouble with running out of storage space on your laptop, or if you noticed the storage speeds are getting slow and want to replace it. You may want to wear an anti-static strap but that is optional as it should be fine to do this process without one.
Before you begin this process make sure to completely shut down the laptop. It will require that you take off the bottom panel on the laptop, remove the screw holding the SSD in place, and lift the SSD out of its slot.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: passo 1, imagem 1 %32
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: passo 2, imagem 1 %32 Dell XPS 15 9500 SSD Replacement: passo 2, imagem 2 %32
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: passo 3, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: passo 4, imagem 1 %32
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: passo 5, imagem 1 %32 Dell XPS 15 9500 SSD Replacement: passo 5, imagem 2 %32
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Conclusão
Bryan Chung
Membro desde: 10/18/19
437 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 85
Ao todo: 4,942
