Dell Vostro 1400 Speakers Replacement
Introdução
Vá para o passo 1This guide will show you the proper steps to replace your speakers in your Dell Vostro 1400 Laptop.
Computer speakers allow any audio played to be transmitted out loud without the use of headphones. Speakers that are not functional will produce either distorted sound or no sound at all.
Before using this guide, make sure to remove the hard drive, the battery, and the RAM.
Before beginning, make sure the device is powered off and disconnected from any power source.
O que você precisa
Ferramentas
Exibir mais…
After flipping over the laptop, the battery is on the bottom side of the laptop.
Find the tabs on both the left and right side of the battery.
Unscrew both screws on the hard drive panel until the panel is able to be removed.
Once screws have been loosened, remove the panel from the laptop.
Loosen the three 3 mm screws on the RAM cover.
Lift the cover and remove it from the laptop.
Loosen the 3 screws holding down the panel for the CPU processor door.
Loosen the 4 heat sink screws and lift the heat sink away from the motherboard.
Uma outra pessoa concluiu este guia.
