Dell Vostro 14 3468 Memory Module Replacement
O que você precisa
Ferramentas
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe, push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
Disconnect the optical drive connector and lift it to remove it from the system board [1].
Remove the screws inside the palmrest [2].
Pull the clips securing the memory module until the memory module pops up [1].
Remove the memory module from the system board [2].
Uma outra pessoa concluiu este guia.
