Ir para o conteúdo principal
Dell Precision M6400 Memory Module Replacement
Johnathan Hammond
Johnathan Hammond e um outro colaborador
Última atualização em November 10, 2019
10 - 20 minutos
Fácil
Guia colaborativo
O que você precisa
Ferramentas
  1. Dell Precision M6400 Memory Module Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: passo 2, imagem 1 %32
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: passo 3, imagem 1 %32
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: passo 4, imagem 1 %32
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: passo 5, imagem 1 %32
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.264 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,358
