Ir para o conteúdo principal
Dell Latitude E7470 SSD Replacement
Hyperion
Hyperion e 2 outros colaboradores
Última atualização em January 21, 2021
15 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
Replacing the internal m.2 SSD of a Dell Latitude E7470. You can only choose a 2280 m.2 SSD, the other sizes are not compatible with this PC.
  1. Dell Latitude E7470 SSD Replacement, Open cover: passo 1, imagem 1 %32 Dell Latitude E7470 SSD Replacement, Open cover: passo 1, imagem 2 %32 Dell Latitude E7470 SSD Replacement, Open cover: passo 1, imagem 3 %32
    • Begin by removing the 8 screws circled in red on the photo opposite with a Philips # 0 screwdriver.
    • Next, using the iFixit Opening Picks, lift the cover up from the dock connector. Unclip it gently.
    It's a good idea to disconnect the Battery before removing any components. This is the pull tab to the left of the NAND SSD and above the battery
    Richard Holmes - Responder
  2. Dell Latitude E7470 SSD Replacement, Changing the SSD: passo 2, imagem 1 %32 Dell Latitude E7470 SSD Replacement, Changing the SSD: passo 2, imagem 2 %32 Dell Latitude E7470 SSD Replacement, Changing the SSD: passo 2, imagem 3 %32
    • After removing the cover, the SSD slot is on the bottom right, right next to the battery.
    • Make sure you have grounded yourself before you start handling. There is a huge risk of damaging components. Use an antistatic wrist strap.
    • To remove the SSD, simply remove the single screw that holds it. Lift the SSD to a 30-degree angle and pull it from its slot.
Conclusão
To reassemble your device, follow the instructions in reverse order.
6 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Hyperion
Membro desde: 12/13/15
2.004 Reputação
Autoria de 3 guias
8Comentários do guia
Does the M.2 interface in this board support NVMe M.2 SSD’s?
Kinetik - Responder
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
Luke Johnson -
It’s not working for me with Kingston nvme NV1
Ravi Bhargava - Responder
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Mike Heiss - Responder
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Is it possible to install two SSD on this Dell Latitude e7470 laptop? I am currently eyeing one and would like to know if to purchase an extra SSD for it.
Thanks in advance.
Ekerette Ekpo - Responder
No extra slot for a extra ssd card. But you can insert High capacity SD card into the Card Slot to give you more disk memory.!
Burgert Adriaan Potgieter -
Dumb question maybe - how do you get the cover back on? The front specifically doesn't seem to line up with anything on the main chassis.
Michael Jantzen - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 133
Ao todo: 21,131
