Ir para o conteúdo principal
Dell Latitude E7440 RAM Replacement
Akash Kedia
Akash Kedia e um outro colaborador
Última atualização em March 6, 2019
5 minutos
Fácil
You may have noticed your computer slowing down when using several programs. This is likely a result of insufficient RAM. Fortunately, Dell made RAM replacement straightforward, allowing you to easily upgrade your RAM capacity.
O que você precisa
Ferramentas
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: passo 1, imagem 1 %32
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: passo 2, imagem 1 %32 Dell Latitude E7440 RAM Replacement, Release the battery: passo 2, imagem 2 %32 Dell Latitude E7440 RAM Replacement, Release the battery: passo 2, imagem 3 %32
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: passo 3, imagem 1 %32
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: passo 4, imagem 1 %32 Dell Latitude E7440 RAM Replacement, RAM: passo 4, imagem 2 %32
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: passo 5, imagem 1 %32 Dell Latitude E7440 RAM Replacement: passo 5, imagem 2 %32
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: passo 6, imagem 1 %32 Dell Latitude E7440 RAM Replacement: passo 6, imagem 2 %32 Dell Latitude E7440 RAM Replacement: passo 6, imagem 3 %32
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
Conclusão
6 outras pessoas executaram este guia.
Akash Kedia
Membro desde: 01/24/19
1.445 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, White Winter 2019 Membro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 53
Duração total: 2,890
