Ir para o conteúdo principal
Dell Latitude E7440 Keyboard Replacement
Sheetal Prasanna
Sheetal Prasanna e 3 outros colaboradores
Última atualização em December 19, 2019
35 minutos
Moderado
Introdução
Ir para o passo 1
If the keyboard of your Dell Latitude E7440 is damaged in any form, use this guide to replace the trackpad.
The keyboard is the main input device used in operating the laptop. A damaged or worn out keyboard or a keyboard with missing keys can be a hindrance while using the laptop.
Before using this guide, clean the keyboard using a soft cloth so that it is free of debris.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 2, imagem 3 %32
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 3, imagem 3 %32
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
    Note that their left hand is holding a thin black plastic covering that first needs to be pulled back.
    threeringcircus - Responder
  4. Dell Latitude E7440 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: passo 5, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 1 %32 Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 2 %32 Dell Latitude E7440 Keyboard Replacement: passo 6, imagem 3 %32
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
Conclusão
6 outras pessoas executaram este guia.
Sheetal Prasanna
Membro desde: 11/06/19
649 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G1, Stella Fall 2019 Membro de IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Membros
Autoria de 3 guias
2 comentários
for step three i would add “ the cables to be removed are under a type of flap/cover”. I don’t know if we have to be specific on what tools we used. If we do have to be specific than we will just add them. Other than that great work!
Oscar Aca - Responder
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
Jamie O'Hare - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 43
Ao todo: 5,440
