Ir para o conteúdo principal
Dell Latitude E6330 Hard-Drive Replacement
John Donahue
John Donahue e 5 outros colaboradores
Última atualização em November 18, 2022
2 minutos
Fácil
Precisa de melhores imagens
Precisa de mais images
Introdução
Ir para o passo 1
A hard drive is a component of a computer that is responsible for holding all of your documents, downloads, photos, and more.  Sometimes, a hard drive might need to be replaced if it breaks, or if the user wants more storage.  This guide will help you replace the hard drive on your Dell Latitude E6330 laptop with only a few simple steps.
Prior to beginning this guide, be sure to power off the device, unplug it from the charger and disconnect or remove the battery.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell Latitude E6330 Hard-Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn off computer by holding down the power button
  2. Dell Latitude E6330 Hard-Drive Replacement: passo 2, imagem 1 %32 Dell Latitude E6330 Hard-Drive Replacement: passo 2, imagem 2 %32 Dell Latitude E6330 Hard-Drive Replacement: passo 2, imagem 3 %32
    • Slide latches out to unlock and remove battery.
  3. Dell Latitude E6330 Hard-Drive Replacement, Hard-Drive: passo 3, imagem 1 %32
    • Flip the laptop over so the bottom face is facing up.
    • Only follow the battery replacement guide up to removal. You do not need to replace the battery as well if you are replacing the hard-drive. Removal is only done to prevent damage to the laptop.
  4. Dell Latitude E6330 Hard-Drive Replacement: passo 4, imagem 1 %32
    • Using the Phillips #00, remove the two 2.5mm x 5mm screws located at the front left corner of the laptop.
  5. Dell Latitude E6330 Hard-Drive Replacement: passo 5, imagem 1 %32
    • Slide the hard drive & caddy out of its slot.
Conclusão
Uma outra pessoa concluiu este guia.
John Donahue
Membro desde: 03/30/17
130 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 34
Ao todo: 1,545
