Ir para o conteúdo principal
Dell Latitude E5550-5550 Hard Drive Replacement
Hezekiah Brown
Hezekiah Brown e um outro colaborador
Última atualização em August 4, 2021
1 - 3 minutos
Fácil
Pontos lista!
Precisa de mais images
Guia colaborativo
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery and base cover from the computer.
  1. Dell Latitude E5550-5550 Hard Drive Replacement, Remove screws and cable.: passo 2, imagem 1 %32
    • Disconnect the hard-drive cable from its connector on the system board [1] .
    • Remove the screws that secure the hard-drive assembly to the computer [2].
  2. Dell Latitude E5550-5550 Hard Drive Replacement, Remove hard drive assembly: passo 3, imagem 1 %32
    • Remove the hard-drive assembly from the computer.
  3. Dell Latitude E5550-5550 Hard Drive Replacement, Release hard-drive cable: passo 4, imagem 1 %32
    • Pull to release the hard-drive cable from its connector.
  4. Dell Latitude E5550-5550 Hard Drive Replacement, Remove screws to hard-drive bracket.: passo 5, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive [1] and remove the hard drive from the hard-drive bracket [2].
    • Place the hard-drive bracket on the hard drive to align the screw holders and tighten the screws to secure the hard-drive bracket.
    • Connect the hard-drive cable to its connector on the hard drive.
    • Place the hard-drive assembly into its slot on the computer.
    • Connect the hard-drive cable to its connector on the system board.
    • Tighten the screws to secure the hard-drive assembly to the computer.
    • Install the battery and base cover.
Conclusão
Hezekiah Brown
Membro desde: 02/11/21
6.169 Reputação
Autoria de 49 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 854
