Ir para o conteúdo principal
Dell Latitude E5500 Bluetooth Card Replacement
Richard Harrison
Richard Harrison e 4 outros colaboradores
Última atualização em May 7, 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
If the user would like to replace a faulty Bluetooth card, or one that is not powerful enough, this guide will give step by step information on how to achieve this.
O que você precisa
Ferramentas
  1. Dell Latitude E5500 Bluetooth Card Replacement, Bluetooth Card: passo 1, imagem 1 %32
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Bluetooth Card Replacement: passo 2, imagem 1 %32 Dell Latitude E5500 Bluetooth Card Replacement: passo 2, imagem 2 %32
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Bluetooth Card Replacement: passo 3, imagem 1 %32 Dell Latitude E5500 Bluetooth Card Replacement: passo 3, imagem 2 %32
    • The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
  4. Dell Latitude E5500 Bluetooth Card Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the wire connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Bluetooth Card Replacement: passo 5, imagem 1 %32
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Bluetooth Card Replacement: passo 6, imagem 1 %32 Dell Latitude E5500 Bluetooth Card Replacement: passo 6, imagem 2 %32
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
Conclusão
4 outras pessoas executaram este guia.
Richard Harrison
Membro desde: 10/23/16
805 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 2,631
