Ir para o conteúdo principal
Dell Latitude E5450-5450 LCD Screen Replacement
Tulsi Panchal
Tulsi Panchal e um outro colaborador
Última atualização em December 10, 2020
10 minutos
Fácil
Introdução
Ir para o passo 1
You can use this guide in order to replace the screen of a Dell Latitude E5450 laptop.
There are so many different types of laptop screens available in the market such as transmissive screens, reflective screens, transflective screens, widescreens, backlit LED displays, and many more. I would recommend buying a laptop screen which prevents eye strain.
Every display panel is made up of a series of dots called pixels. In general, the higher the pixel count, the better the display.
To begin with the screen replacement process, you need a Phillips #0 screwdriver. Before performing any task, you must unplug the laptop from a charger or any other device. Then remove the battery which can help to prevent shock.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Dell Latitude E5450-5450 LCD Screen Replacement, Unscrew the Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Remove the six Philips #0 screws from the lower case.
    • These screws are all 5.6 mm long, but it's still a good idea to keep track of them and make sure they go back in their proper holes!
  2. Dell Latitude E5450-5450 LCD Screen Replacement: passo 2, imagem 1 %32
    • This photo shows the location of the ten clips that hold the lower case in place. Take note of the location of the clips, and refer back to this step if your lower case gets stuck during removal.
    • Four clips hold the upper half of the case in place and can be released by prying around them with a spudger.
    • The other six clips along the bottom edge can not be released by prying at them. Instead, they come free by sliding the whole case upward, as shown in step 5 below.
  3. Dell Latitude E5450-5450 LCD Screen Replacement: passo 3, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 3, imagem 2 %32
    • Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
    • Pry up to release the two central clips along the upper edge of the case.
  4. Dell Latitude E5450-5450 LCD Screen Replacement: passo 4, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 4, imagem 2 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 4, imagem 3 %32
    • Use your spudger to pry up the remaining clips along the top edge.
  5. Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: passo 5, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: passo 5, imagem 2 %32 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Lower Case: passo 5, imagem 3 %32
    • Slide the lower case upward and remove it.
  6. Dell Latitude E5450-5450 LCD Screen Replacement: passo 6, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 6, imagem 2 %32
    • When reinstalling the lower case, make sure you slide the bottom edge (the edge without the cutout) into place first before snapping the rest of the clips shut.
  7. Dell Latitude E5450-5450 LCD Screen Replacement, Disconnect the Battery: passo 7, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement, Disconnect the Battery: passo 7, imagem 2 %32
    • Pull up on the battery connector's pull tab to disconnect the battery.
  8. Dell Latitude E5450-5450 LCD Screen Replacement, Unscrew the Battery: passo 8, imagem 1 %32
    • Remove the three 5.6 mm Philips #0 screws from the top edge of the battery.
  9. Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: passo 9, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: passo 9, imagem 2 %32 Dell Latitude E5450-5450 LCD Screen Replacement, Remove the Battery: passo 9, imagem 3 %32
    • Remove the battery from the laptop.
    • The battery cell extends below the bottom lip of the enclosure. Make sure you lift the battery away from the bottom edge of the laptop at an angle, as shown in the photos.
  10. Dell Latitude E5450-5450 LCD Screen Replacement: passo 10, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 10, imagem 2 %32
    • When installing your new battery, slide the bottom edge in first, and make sure it lays flat before you proceed to reinsert the screws or reconnect it.
  11. Dell Latitude E5450-5450 LCD Screen Replacement, LCD Screen: passo 11, imagem 1 %32
    • Flip the laptop so the front panel is facing you.
    • Open the laptop.
  12. Dell Latitude E5450-5450 LCD Screen Replacement: passo 12, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 12, imagem 2 %32
    • Remove the plastic cover surrounding the screen.
    • Remove the four Phillips #0 screws from each corner of the laptop.
  13. Dell Latitude E5450-5450 LCD Screen Replacement: passo 13, imagem 1 %32 Dell Latitude E5450-5450 LCD Screen Replacement: passo 13, imagem 2 %32
    • Carefully put the screen upside down on the keyboard.
    • Disconnect the cable with the QR code on the opposite side of the screen.
  14. Dell Latitude E5450-5450 LCD Screen Replacement: passo 14, imagem 1 %32
    • Remove the screen from the laptop.
Conclusão
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, then please reapply it and let it dry before you start using the laptop.
3 outras pessoas executaram este guia.
Tulsi Panchal
Membro desde: 09/17/20
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 54
Ao todo: 3,122
