Ir para o conteúdo principal
Dell Latitude E5450 Lower Case Replacement
O que você precisa
  1. Dell Latitude E5450 Lower Case Replacement, Unscrew the Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Remove the six Philips #0 screws from the lower case.
    • These screws are all 5.6 mm long, but it's still a good idea to keep track of them and make sure they go back in their proper holes!
  2. Dell Latitude E5450 Lower Case Replacement: passo 2, imagem 1 %32
    • This photo shows the location of the ten clips that hold the lower case in place. Take note of the location of the clips, and refer back to this step if your lower case gets stuck during removal.
    • Four clips hold the upper half of the case in place and can be released by prying around them with a spudger.
    • The other six clips along the bottom edge can not be released by prying at them. Instead, they come free by sliding the whole case upward, as shown in step 5 below.
  3. Dell Latitude E5450 Lower Case Replacement: passo 3, imagem 1 %32 Dell Latitude E5450 Lower Case Replacement: passo 3, imagem 2 %32
    • Insert the flat edge of a spudger into the small divot along the top edge of the case, just below the docking station port.
    • Pry up to release the two central clips along the upper edge of the case.
  4. Dell Latitude E5450 Lower Case Replacement: passo 4, imagem 1 %32 Dell Latitude E5450 Lower Case Replacement: passo 4, imagem 2 %32 Dell Latitude E5450 Lower Case Replacement: passo 4, imagem 3 %32
    • Use your spudger to pry up the remaining clips along the top edge.
  5. Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: passo 5, imagem 1 %32 Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: passo 5, imagem 2 %32 Dell Latitude E5450 Lower Case Replacement, Remove the Lower Case: passo 5, imagem 3 %32
    • Slide the lower case upward and remove it.
  6. Dell Latitude E5450 Lower Case Replacement: passo 6, imagem 1 %32 Dell Latitude E5450 Lower Case Replacement: passo 6, imagem 2 %32
    • When reinstalling the lower case, make sure you slide the bottom edge (the edge without the cutout) into place first before snapping the rest of the clips shut.
Conclusão
Repair didn’t go as planned? Check out our Dell Latitude answers community for troubleshooting help.
Taylor Dixon
Membro desde: 06/26/18
69.720 Reputação
Autoria de 94 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 1,736
