Dell Latitude D620 RAM Replacement
Introdução
Ir para o passo 1Guide to installing new RAM modules for the Dell Latitude D620.
O que você precisa
With the keyboard removed, you should be able to see ram slot A.
Place new ram into the slot making sure it is aligned
26 outras pessoas executaram este guia.
2Comentários do guia
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
Please help me
manaqib arif - Responder
Mera display ka masla hai
