Ir para o conteúdo principal
Dell Latitude 3190 M.2 SSD Replacement
Daniel Tzunum
Daniel Tzunum e 5 outros colaboradores
Última atualização em January 9, 2025
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
If your Dell Latitude 3190 laptop is showing the black screen of death, taking a long time to startup or is slow to load applications, use this guide to replace or upgrade your M.2 SSD for the Dell Latitude.
An SSD is a solid-state drive that uses flash memory to store data in your computer. An SSD provides the computer with better performance and energy consumption.
The laptop’s SSD needs to be upgraded or replaced if the computer is lacking in performance or it is slow to startup and load.
Before starting this repair, power off your device and unplug from the charger.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell Latitude 3190 M.2 SSD Replacement, Base Cover: passo 1, imagem 1 %32 Dell Latitude 3190 M.2 SSD Replacement, Base Cover: passo 1, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 M.2 SSD Replacement: passo 2, imagem 1 %32 Dell Latitude 3190 M.2 SSD Replacement: passo 2, imagem 2 %32 Dell Latitude 3190 M.2 SSD Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: passo 3, imagem 1 %32 Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: passo 3, imagem 2 %32 Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: passo 3, imagem 3 %32
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  4. Dell Latitude 3190 M.2 SSD Replacement: passo 4, imagem 1 %32 Dell Latitude 3190 M.2 SSD Replacement: passo 4, imagem 2 %32 Dell Latitude 3190 M.2 SSD Replacement: passo 4, imagem 3 %32
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Tzunum
Membro desde: 09/01/21
235 Reputação
Autoria de 2 guias
Equipe
Gateway, Team 1-5, Saknee Fall 2021 Membro de Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Membros
Autoria de 9 guias
1Comentário do guia
It's worth noting that some Latitude 3190s use eMMC storage, and these lack the M2 socket on the motherboard, although it would be possible to solder one on (the 80mm standoff and screw are present!)
Tim Walker - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 100
Ao todo: 4,405
