Ir para o conteúdo principal
Dell Inspiron 17-5749 Hard Drive Replacement
Christopher Tran
Christopher Tran e 3 outros colaboradores
Última atualização em April 25, 2024
15 minutos
Fácil
Introdução
Ir para o passo 1
Are you having problems with the hard drive in your Dell Inspiron 17-5749 that include but not limited to:
  • The drive producing strange sounds
  • The drive dropping in performance (becomes slower)
  • The capacity is no longer sufficient
  • Or the drive has simply reached the end of its lifespan?
Well not to worry, this guide will allow you to remove and replace the hard drive with ease! (please make sure to back up your data before beginning!)
O que você precisa
Ferramentas
  1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 17-5749 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 17-5749 Hard Drive Replacement: passo 2, imagem 2 %32
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: passo 3, imagem 1 %32 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: passo 3, imagem 2 %32 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: passo 3, imagem 3 %32
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Tran
Membro desde: 02/13/18
1.162 Reputação
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 736
