Dell Inspiron 13-7359 Battery Replacement
Introdução
Ir para o passo 1This guide will show you how to replace your device's battery without any hiccups. You will need one Phillips #0 screwdriver and one plastic spudger.
O que você precisa
Ferramentas
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
4 outras pessoas executaram este guia.
