Introdução
If you notice your computer overheating and it is not because of the fan, this guide may be able to help. This guide will show you how to replace the heat sink in a few steps.
Ferramentas
Peças
Não são necessárias peças.
Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
Unplug the daughter board cable in two places marked in red, then remove it.
Unplug the fan cable marked in orange.
Remove 3 M2 2mm screws, using the Phillips 0 screwdriver, on the heat sink.
Remove the heat sink.
